Ir para o conteúdo principal
Crosley CR42 Power Cable Replacement
O que você precisa
  1. Crosley CR42 Power Cable Replacement, Power Cable: passo 1, imagem 1 %32 Crosley CR42 Power Cable Replacement, Power Cable: passo 1, imagem 2 %32
    • Turn the device around until you are looking at the line-out port.
    • With a cordless drill or Phillips #0 screwdriver, remove the ten 12-mm screws.
  2. Crosley CR42 Power Cable Replacement: passo 2, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 2, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 2, imagem 3 %32
    • Gently remove the back of the device. It should be connected by two wires.
  3. Crosley CR42 Power Cable Replacement: passo 3, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 3, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 3, imagem 3 %32
    • Gently remove both wires.
    • After de-threading the antenna wire, remove the back of the device and set it aside.
  4. Crosley CR42 Power Cable Replacement: passo 4, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 4, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 4, imagem 3 %32
    • Locate where the power cable connects to the device.
    • Pick up the device and locate the screw holding the small black peg to the device. Unscrew it and set the screw aside.
  5. Crosley CR42 Power Cable Replacement: passo 5, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 5, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 5, imagem 3 %32
    • With the pliers, remove the wire connectors. You may need to be forceful
    • It is wise to attach a marking in order to recognize how the wires should be reattached.
  6. Crosley CR42 Power Cable Replacement: passo 6, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 6, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 6, imagem 3 %32
    • Pull apart both groups of wires.
    • After getting your replacement power cord, make sure you recognize how the wires should reattach.
  7. Crosley CR42 Power Cable Replacement: passo 7, imagem 1 %32 Crosley CR42 Power Cable Replacement: passo 7, imagem 2 %32 Crosley CR42 Power Cable Replacement: passo 7, imagem 3 %32
    • Twist the connecting wires together.
    • Attach the twist-on wire connectors to the exposed wires.
Conclusão
Uma outra pessoa concluiu este guia.
Eric Dybsetter
Membro desde: 01/26/14
193 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-38, Maness Winter 2014 Membro de Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 57
Ao todo: 6,812
