Introdução
Bushings are the rubber components in record players. Worn or loose bushings need to be replaced. This guide shows how to replace the bushings in the Crosley CR42 Player.
O que você precisa
Turn the device around so the line out port faces you.
Remove the ten 12 mm screws with the Phillips screwdriver.
Uma outra pessoa concluiu este guia.
