Ir para o conteúdo principal
Crosley CR42 Bushings Replacement
O que você precisa
  1. Crosley CR42 Bushings Replacement, Bushings: passo 1, imagem 1 %32 Crosley CR42 Bushings Replacement, Bushings: passo 1, imagem 2 %32
    • Turn the device around so the line out port faces you.
    • Remove the ten 12 mm screws with the Phillips screwdriver.
  2. Crosley CR42 Bushings Replacement: passo 2, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 2, imagem 2 %32 Crosley CR42 Bushings Replacement: passo 2, imagem 3 %32
    • Pull the line out port toward you so you can view the inside of the Crosley.
    • Locate the wires that connect the line out port to the inside of the device.
  3. Crosley CR42 Bushings Replacement: passo 3, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 3, imagem 2 %32 Crosley CR42 Bushings Replacement: passo 3, imagem 3 %32
    • Pull on the two connections to remove them from the back of the line out port.
    • Remove the antenna wire from the line out port, then remove the line out port and set it aside.
  4. Crosley CR42 Bushings Replacement: passo 4, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 4, imagem 2 %32
    • Remove the red and black connection underneath the turntable.
  5. Crosley CR42 Bushings Replacement: passo 5, imagem 1 %32
    • Position yourself in front of the turntable to unscrew the three bushing bolts.
  6. Crosley CR42 Bushings Replacement: passo 6, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 6, imagem 2 %32 Crosley CR42 Bushings Replacement: passo 6, imagem 3 %32
    • Unscrew the three bushing bolts with the Phillips screw driver.
  7. Crosley CR42 Bushings Replacement: passo 7, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 7, imagem 2 %32
    • Pull the turntable out from the casing.
    • Remove the three bushing bolts.
  8. Crosley CR42 Bushings Replacement: passo 8, imagem 1 %32 Crosley CR42 Bushings Replacement: passo 8, imagem 2 %32 Crosley CR42 Bushings Replacement: passo 8, imagem 3 %32
    • Pinch the rubber bushing at the bottom, then pull downwards to remove it.
    • Repeat the previous step for the other two bushings.
Conclusão
Uma outra pessoa concluiu este guia.
Roberto Rosila
Membro desde: 01/26/14
319 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-38, Maness Winter 2014 Membro de Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 3,084
