Introdução
This guide will tell you how to replace the face of the Crosley 33301 alarm clock.
O que você precisa
Rotate Clock till the face/or front is pointing away from you.
Continue on by unscrewing the 5.5 millimeter screws with your hands.
Once all the screws are removed, take the circular back panel off and lay it down flat on a stable surface to put back on later.
