Ir para o conteúdo principal
Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement
O que você precisa
  1. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: passo 1, imagem 1 %32 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: passo 1, imagem 2 %32 Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Lid: passo 1, imagem 3 %32
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  2. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement, Bobber Valve: passo 2, imagem 1 %32
    • Flip the lid over and expose plastic washer.
  3. Crock-Pot Express Crock Multi-Cooker Bobber Valve Replacement: passo 3, imagem 1 %32
    • Pull the plastic washer off the bobber valve and allow the bobber valve to fall out
Conclusão
6 outras pessoas executaram este guia.
7 comentários
Ok I followed your directions but the new valve just keeps calling out?
dpataky1952 - Responder
First time I used this but the bobber valve ports steam and does not stop ( unit is brand new )
Archerkc - Responder
would be nice to see the other side of this. is it just supposed to be a hole on the outside up top? it is letting out air…when im trying to pressure cook.
shaycooks2 - Responder
Ditto I was wanting to know the same thing!
kate2272 -
Ditto. Mine does the same thing.. suggestions?
Tina Royce - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 97
Duração total: 26,637
