Ir para o conteúdo principal
Cricut Maker Top Door/ Lid Replacement
O que você precisa
  1. Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: passo 1, imagem 1 %32 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: passo 1, imagem 2 %32 Cricut Maker Top Door/ Lid Replacement, Cricut Maker Lid Replacement: passo 1, imagem 3 %32
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Top Door/ Lid Replacement: passo 2, imagem 1 %32 Cricut Maker Top Door/ Lid Replacement: passo 2, imagem 2 %32
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Top Door/ Lid Replacement: passo 3, imagem 1 %32 Cricut Maker Top Door/ Lid Replacement: passo 3, imagem 2 %32 Cricut Maker Top Door/ Lid Replacement: passo 3, imagem 3 %32
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Top Door/ Lid Replacement: passo 4, imagem 1 %32
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
Conclusão
3 outras pessoas executaram este guia.
Devyn White
Membro desde: 09/20/22
1.041 Reputação
Autoria de 5 guias
Equipe
Um comentário
Where i can buy Cricut Maker Top Door/ Lid Replacement?
Maria Ventura - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 143
Duração total: 1,867
