Ir para o conteúdo principal
Cricut Maker Belt Replacement
O que você precisa
  1. Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: passo 1, imagem 1 %32 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: passo 1, imagem 2 %32 Cricut Maker Belt Replacement, Cricut Maker Lid Replacement: passo 1, imagem 3 %32
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
    The outer two attachment points of my Cricut were actually glued on, and I had to reach in with the torx driver and remove them while the strip was still on, to be able to get the lid off. On inspection, there would have been no way to lift the strip off in the way described here.
    cjberry - Responder
  2. Cricut Maker Belt Replacement: passo 2, imagem 1 %32 Cricut Maker Belt Replacement: passo 2, imagem 2 %32
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Belt Replacement: passo 3, imagem 1 %32 Cricut Maker Belt Replacement: passo 3, imagem 2 %32 Cricut Maker Belt Replacement: passo 3, imagem 3 %32
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
    The lid of my Cricut maker 3 was removable by pulling upwards, while the lid was still open. It slides right off. The prying approach as described in this step is unnecessary, and could break the attachment points if forced.
    Chris Schnabel - Responder
  4. Cricut Maker Belt Replacement: passo 4, imagem 1 %32
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
    Where is/are the steps to get to the point of seeing the motor? I've got the top cover off, but that doesn't reveal the motor. There are steps missing between 4 and 5.
    Patty Ellis - Responder
    There are x7 small screws on the inside upper panel that have to be removed as well as x4 long screws under the feet of the machine.
    I had to turn on my machine and send a project to it to have the cutter mechanism move out of the way to remove some of the screws. Once all the screws have been removed the case can be pulled away, but you have to be careful when removing because there are some wires connecting the buttons on the case to the harddrive.
    Margarita Armendariz -
    Where can I get the replacement part(s) to make the door stay up and open?
    David L Dabbs - Responder
  5. Cricut Maker Belt Replacement, Front Door Replacement: passo 5, imagem 1 %32 Cricut Maker Belt Replacement, Front Door Replacement: passo 5, imagem 2 %32
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Belt Replacement: passo 6, imagem 1 %32 Cricut Maker Belt Replacement: passo 6, imagem 2 %32 Cricut Maker Belt Replacement: passo 6, imagem 3 %32
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Belt Replacement: passo 7, imagem 1 %32 Cricut Maker Belt Replacement: passo 7, imagem 2 %32 Cricut Maker Belt Replacement: passo 7, imagem 3 %32
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
    A right-angle attachment can also be used. A mechanic's mirror is also helpful because you can't really see a few of the screws unless you're a contortionist.
    Waterit - Responder
  8. Cricut Maker Belt Replacement: passo 8, imagem 1 %32 Cricut Maker Belt Replacement: passo 8, imagem 2 %32 Cricut Maker Belt Replacement: passo 8, imagem 3 %32
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
    When removing the top of the case, be sure to disconnect the daughter board on the right side of the machine.
    Tovakiin - Responder
  9. Cricut Maker Belt Replacement: passo 9, imagem 1 %32 Cricut Maker Belt Replacement: passo 9, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Belt Replacement: passo 10, imagem 1 %32 Cricut Maker Belt Replacement: passo 10, imagem 2 %32 Cricut Maker Belt Replacement: passo 10, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
    Note the empty screw hole in the second photo, on the front, just beneath the plastic fin.
    How was this removed without damaging the fin?
    Hint: Since we've already removed the screws holding the right side cover in Step 9, the cover could be moved inward, providing access to that screw, IF we had already removed the lid attachment/hinge mechanism and rear inside cover.
    JCinGG - Responder
  11. Cricut Maker Belt Replacement: passo 11, imagem 1 %32 Cricut Maker Belt Replacement: passo 11, imagem 2 %32
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
    I need to replace that bundled connector cord - where can I find one?
    Jade9767 - Responder
  12. Cricut Maker Belt Replacement: passo 12, imagem 1 %32 Cricut Maker Belt Replacement: passo 12, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Belt Replacement: passo 13, imagem 1 %32 Cricut Maker Belt Replacement: passo 13, imagem 2 %32 Cricut Maker Belt Replacement: passo 13, imagem 3 %32
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
    Why is this step here, and not a step to remove the lid attachment hinge mechanism and rear inside cover?
    It is not necessary to remove the front door for this procedure.
    JCinGG - Responder
  14. Cricut Maker Belt Replacement: passo 14, imagem 1 %32 Cricut Maker Belt Replacement: passo 14, imagem 2 %32 Cricut Maker Belt Replacement: passo 14, imagem 3 %32
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Belt Replacement, Motor: passo 15, imagem 1 %32 Cricut Maker Belt Replacement, Motor: passo 15, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
    In this step, we can see the lid attachment hinge mechanism has been removed.
    How was that done? And how are the damper/spring units adjusted after they are reinstalled?
    I also don't know why this motor needs to be removed to replace a belt.
    JCinGG - Responder
    Remove the black screws on the right side first. When re-assembling, install them first.
    Waterit - Responder
  16. Cricut Maker Belt Replacement: passo 16, imagem 1 %32
    • Remove the motor by pulling it from the device.
    No need to remove this for a belt replacement.
    JCinGG - Responder
  17. Cricut Maker Belt Replacement: passo 17, imagem 1 %32
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
  18. Cricut Maker Belt Replacement: passo 18, imagem 1 %32 Cricut Maker Belt Replacement: passo 18, imagem 2 %32
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
    That "washer" is properly known as an "E-clip".
    JCinGG - Responder
    Do you know here i can get a replacement for the large white gear that drives the belt?
    Rom Koutnik - Responder
  19. Cricut Maker Belt Replacement: passo 19, imagem 1 %32 Cricut Maker Belt Replacement: passo 19, imagem 2 %32
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
    I fail to see why this motor needs to be removed from it's bracket.
    Steps 21 and 22 should already have been done first, then you can just push the axle pin out, and free the gear from the belt.
    JCinGG - Responder
    Bonjour, à quel moment enlève t on l'arrière de la machine pour accéder au porte outil?
    Maserati Rolish - Responder
  20. Cricut Maker Belt Replacement: passo 20, imagem 1 %32 Cricut Maker Belt Replacement: passo 20, imagem 2 %32
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
    JCinGG - Responder
  21. Cricut Maker Belt Replacement, Belt: passo 21, imagem 1 %32 Cricut Maker Belt Replacement, Belt: passo 21, imagem 2 %32 Cricut Maker Belt Replacement, Belt: passo 21, imagem 3 %32
    • Remove the two 10 mm screws using a Phillips #2 screwdriver.
  22. Cricut Maker Belt Replacement: passo 22, imagem 1 %32 Cricut Maker Belt Replacement: passo 22, imagem 2 %32
    • Pull the belt holder towards you, and twist it sideways to slide it neatly into the same hole the belt is emerging from.
  23. Cricut Maker Belt Replacement: passo 23, imagem 1 %32 Cricut Maker Belt Replacement: passo 23, imagem 2 %32
    • Pull the bar containing the axel and metal attachment out to remove them.
    • This should free the remaining side of the belt.
  24. Cricut Maker Belt Replacement: passo 24, imagem 1 %32 Cricut Maker Belt Replacement: passo 24, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the board on the main motor.
  25. Cricut Maker Belt Replacement: passo 25, imagem 1 %32 Cricut Maker Belt Replacement: passo 25, imagem 2 %32 Cricut Maker Belt Replacement: passo 25, imagem 3 %32
    • Remove the electrical tape from the connecting cable on the backside of the main motor.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Pull the cable out.
  26. Cricut Maker Belt Replacement: passo 26, imagem 1 %32 Cricut Maker Belt Replacement: passo 26, imagem 2 %32 Cricut Maker Belt Replacement: passo 26, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws from the belt holder under the main motor.
    • Removing these two screws will cause the belt holder to detach.
    • Slip it through the hole in the main motor frame.
  27. Cricut Maker Belt Replacement: passo 27, imagem 1 %32 Cricut Maker Belt Replacement: passo 27, imagem 2 %32
    • Remove the washer (e-clip) securing the bar to the belt holder.
    • We found it is easiest to remove by hand.
    • To remove it, simply twist and pull upwards to free it.
    • Remove the bar from the belt holder and then remove the belt holder.
    • Slip the belt out of the machine.
    JCinGG - Responder
    Where fo you get replacement belt
    Michelle Stone - Responder
Conclusão
4 outras pessoas executaram este guia.
Devyn White
Membro desde: 09/20/22
1.131 Reputação
Autoria de 5 guias
4 comentários
Where can I find the replace for the belt?
Adriahnna Sutton - Responder
Hi… Where can I buy the replace for the belt? In Amazon I find one with this description
GT2 Pitch: 2mm
Belt Height: 1.38mm
Tooth Height: 0.75mm
Material: Rubber
Width: 6mm
Can you confirm if it is similar to the original machine?
Kerilacle - Responder
Wie auch meine Vorredner, würde ich gerne wissen, ob du einen Link zu einem passenden Riemen bereitstellen kannst.
Beste Grüße
Martin Rathke - Responder
No answer on where to buy 😵‍💫😵‍💫😵‍💫
Tina Amburn - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 46
Últimos 30 dias: 200
Ao todo: 7,307
