Ir para o conteúdo principal
Cricut Explore Air 2 Front Door Replacement
O que você precisa
  1. Cricut Explore Air 2 Front Door Replacement, Front Door: passo 1, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement, Front Door: passo 1, imagem 2 %32
    • On both the left and right sides of the Cricut, locate the two internal screws.
    • Use a Phillips #1 screwdriver bit to unscrew the top 10.8 mm screw and the lower 9.1 mm screw on each side, four screws in total.
  2. Cricut Explore Air 2 Front Door Replacement: passo 2, imagem 1 %32
    • Rotate the Cricut so the bottom faces upwards.
  3. Cricut Explore Air 2 Front Door Replacement: passo 3, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 3, imagem 2 %32
    • Locate the four screws, two on the left and two on the right, with pads attached.
    • Using a Phillips #2 screwdriver, remove all four of the screws and their pads.
  4. Cricut Explore Air 2 Front Door Replacement: passo 4, imagem 1 %32
    • Rotate the Cricut back to an upright position.
  5. Cricut Explore Air 2 Front Door Replacement: passo 5, imagem 1 %32
    • Gently lift the left and right sides of the Cricut's plastic shell off.
  6. Cricut Explore Air 2 Front Door Replacement: passo 6, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 6, imagem 2 %32
    • On the right side of the Cricut, locate the circuit board screwed in to the cover just removed.
    • Locate the four screws securing the circuit board to the shell.
    • Use a Phillips #1 screwdriver to unscrew each of the four 10 mm screws.
  7. Cricut Explore Air 2 Front Door Replacement: passo 7, imagem 1 %32
    • Gently unplug the connector from the circuit board, freeing the right side of the plastic shell completely.
  8. Cricut Explore Air 2 Front Door Replacement: passo 8, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 8, imagem 2 %32
    • On both the left and right sides of the back plastic panel.
    • Using a Phillips #2 screwdriver, unscrew each of the four 5mm screws.
  9. Cricut Explore Air 2 Front Door Replacement: passo 9, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 9, imagem 2 %32
    • Wedge a plastic pryer tool next to the left side of the back panel.
    • Gently pry the left side of the back door from the rest of the machine.
    • Repeat with the right side of the back door to completely remove the back panel.
  10. Cricut Explore Air 2 Front Door Replacement: passo 10, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 10, imagem 2 %32
    • On both the left and right sides, locate the screws securing the top door's hinge.
    • Use a Phillips #1 screwdriver to remove the two 6.5 mm screws on each side, four in total.
  11. Cricut Explore Air 2 Front Door Replacement: passo 11, imagem 1 %32
    • Gently lift the lid off of the Cricut.
  12. Cricut Explore Air 2 Front Door Replacement: passo 12, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 12, imagem 2 %32
    • Locate the screws on the corners of the metal interior plate on both the left and right sides.
    • Unscrew the two the 8 mm screws on each side, four in total.
  13. Cricut Explore Air 2 Front Door Replacement: passo 13, imagem 1 %32
    • Gently lean the metal interior and all that comes with it backwards, exposing the bottom plastic shell of the Cricut.
  14. Cricut Explore Air 2 Front Door Replacement: passo 14, imagem 1 %32 Cricut Explore Air 2 Front Door Replacement: passo 14, imagem 2 %32
    • Locate the screws securing the front door hinge to the bottom plate of the Cricut.
    • Unscrew each of the four 5 mm screws on each side, 8 in total.
  15. Cricut Explore Air 2 Front Door Replacement: passo 15, imagem 1 %32
    • Gently remove the front door from the bottom plate of the Cricut.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 27
Duração total: 232
