Ir para o conteúdo principal
Creative Zen Vision W Battery Replacement
O que você precisa
  1. Creative Zen Vision W Battery Replacement, Battery Removal: passo 1, imagem 1 %32 Creative Zen Vision W Battery Replacement, Battery Removal: passo 1, imagem 2 %32 Creative Zen Vision W Battery Replacement, Battery Removal: passo 1, imagem 3 %32
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Creative Zen Vision W Battery Replacement, Battery: passo 2, imagem 1 %32 Creative Zen Vision W Battery Replacement, Battery: passo 2, imagem 2 %32
    • Remove the three 4 mm exposed screws using a Phillips #0 screwdriver.
    • Peel off the the sticker that says "Creative Warranty Void if broken" and remove the 4 mm screw beneath with a Phillips #0 screwdriver.
    I am having trouble finding the replacement battery for my Zen W.
    wayne clements - Responder
  3. Creative Zen Vision W Battery Replacement: passo 3, imagem 1 %32 Creative Zen Vision W Battery Replacement: passo 3, imagem 2 %32 Creative Zen Vision W Battery Replacement: passo 3, imagem 3 %32
    • Remove the battery from the casing by bending the sides. The battery should pop out. Be careful not to snap the case.
Conclusão
Follow these instructions in reverse order to reassemble your device.
Tim Wilson
Membro desde: 04/11/13
143 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 17-2, Regan Spring 2013 Membro de Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
Membros da 4
Autoria de 8 guias
3 comentários
Where can I buy the battery, does not seem to be available on ebay or amazon
Mafaz - Responder
where can i buy this exact battery. Can't find it with 6 tabs, only 4.
Bernie - Responder
Can’t find a replacement battery nor the amp hours or wattage etc.. I’d even be ok with building a new housing to hold a larger battery, but I need the specs… I’ve got a vaccum table and can make a larger case to hold the battery.. But dang I’ve got to know how much power to provide to the unit and at how fast!
Matt Wyckoff - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 35
Duração total: 5,710
