Ir para o conteúdo principal
Creative Zen Vision M Screen Replacement
O que você precisa
  1. Creative Zen Vision M Screen Replacement, Opening the top: passo 1, imagem 1 %32 Creative Zen Vision M Screen Replacement, Opening the top: passo 1, imagem 2 %32
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
  2. Creative Zen Vision M Screen Replacement, Opening the device: passo 2, imagem 1 %32 Creative Zen Vision M Screen Replacement, Opening the device: passo 2, imagem 2 %32
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, imagem 1 %32 Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, imagem 2 %32 Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, imagem 3 %32
    • Disconnect the wire from the bottom device.
    • Handle with care as the wires tend to disconnect easily.
  4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: passo 4, imagem 1 %32
    • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
    • Handle with care as the hard drive also comes off easily.
  5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: passo 5, imagem 1 %32
    • Unscrew the seven screws placed around the mother board.
    • You will need a one millimeter Phillips head screwdriver.
    • The screws are small, so keep them safely.
  6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, imagem 1 %32 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, imagem 2 %32 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, imagem 3 %32
    • Flip your device upside down so that the motherboard will loosen.
    • Detach the connector from the motherboard.
  7. Creative Zen Vision M Screen Replacement, Removing the screen: passo 7, imagem 1 %32 Creative Zen Vision M Screen Replacement, Removing the screen: passo 7, imagem 2 %32
    • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
    • Lift the light gray flap to detach the screen from the motherboard.
  8. Creative Zen Vision M Screen Replacement, Seperating the digital display: passo 8, imagem 1 %32 Creative Zen Vision M Screen Replacement, Seperating the digital display: passo 8, imagem 2 %32
    • Separate the clear screen frame from the digital display.
Conclusão
Uma outra pessoa concluiu este guia.
Kirstie G
Membro desde: 10/12/16
488 Reputação
Autoria de 4 guias
Equipe
Texas Tech, Team 12-1, Bennett Fall 2016 Membro de Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 60
Ao todo: 1,840
