Ir para o conteúdo principal
Creative Zen Vision M Battery Replacement
O que você precisa
  1. Creative Zen Vision M Battery  Replacement, Opening the top: passo 1, imagem 1 %32 Creative Zen Vision M Battery  Replacement, Opening the top: passo 1, imagem 2 %32
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws
  2. Creative Zen Vision M Battery  Replacement, Opening the device: passo 2, imagem 1 %32 Creative Zen Vision M Battery  Replacement, Opening the device: passo 2, imagem 2 %32
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: passo 3, imagem 1 %32 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: passo 3, imagem 2 %32 Creative Zen Vision M Battery  Replacement, Detaching the wires from the screen: passo 3, imagem 3 %32
    • To detach wires from the screen, gently tug on the wires connected to the battery. They are located on the bottom half of the screen.
  4. Creative Zen Vision M Battery  Replacement, Releasing the battery: passo 4, imagem 1 %32
    • To begin removing the battery, move the wires out from under the black foam at the bottom of the device
  5. Creative Zen Vision M Battery  Replacement, Removing the battery: passo 5, imagem 1 %32 Creative Zen Vision M Battery  Replacement, Removing the battery: passo 5, imagem 2 %32
    • Use a plastic opening tool or nylon spudger to lift up the battery.
    • Battery may be glued on the edges.
    • The metal spudger is great for serious prying power, but the regular black nylon spudger should be used whenever possible, especially around batteries.
Conclusão
5 outras pessoas executaram este guia.
Kirstie G
Membro desde: 10/12/16
470 Reputação
Autoria de 4 guias
Equipe
Texas Tech, Team 12-1, Bennett Fall 2016 Membro de Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
Membros da 4
Autoria de 4 guias
Um comentário
Step 1 does not mention that the bottom cover needs to also be removed to access two more screws. Make note of the screw lengths and where they come from.. Two are shorter.
Bob Terwilliger - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 100
Duração total: 4,953
