Ir para o conteúdo principal
Creative Nomad Jukebox Zen Display Screen Replacement
O que você precisa
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 2 %32 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 3 %32
      • Use a J0 screwdriver to remove the eight 3.5mm screws.
      Pergunte ao FixBot
      Comentar
    2. Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 2 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 3 %32
      • Use the plastic opening tool to open the top cover by carefully prying at each corner.
      Pergunte ao FixBot
      Comentar
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: passo 3, imagem 1 %32
      • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
      Pergunte ao FixBot
      Comentar
    1. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: passo 4, imagem 1 %32
      • Using the plastic opening tool to pop the metal tab holding the battery in place.
      • By breaking the sticker, it could void your warranty
      Pergunte ao FixBot
      Comentar
    2. Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, imagem 2 %32
      • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, imagem 2 %32
      • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
      • Using soldering gun with care as it becomes extremely hot and can cause burns.
      Pergunte ao FixBot
      Comentar
    4. Creative Nomad Jukebox Zen Display Screen Replacement: passo 7, imagem 1 %32
      • Using the spudger tool, gently pry up the corners of the display screen to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Austin Shaw
Membro desde: 03/08/17
104 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G5, Baechle Spring 2017 Membro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Membros
Autoria de 60 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 95
Ao todo: 1,003
