Ir para o conteúdo principal
Creative Nomad Jukebox Zen Display Screen Replacement
O que você precisa
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 2 %32 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, imagem 3 %32
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 2 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, imagem 3 %32
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: passo 3, imagem 1 %32
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: passo 4, imagem 1 %32
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, imagem 2 %32
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, imagem 1 %32 Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, imagem 2 %32
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: passo 7, imagem 1 %32
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Conclusão
Austin Shaw
Membro desde: 03/08/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G5, Baechle Spring 2017 Membro de IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 699
