Introdução
How to create Bootable USB Stick for old version of macOS/Mac OSX.
Error : This version of OS X/macOS cannot be installed on this computer.
Download the version of the OS you want to install here: https://support.apple.com/en-gb/HT211683
If you don't get the following error: "This version of OS X/macOS cannot be installed on this computer."
Wait for the end of the installation and follow the following tutorial : Créer une clé USB bootable
Otherwise, go to the next step.
Open the folder appeared on the desktop.
Then, download the files here: https://github.com/ThonyF/iFixitTutoCrea...
Search for the macOS version corresponding to the installation you wish to perform and replace the distribution file in the folder that has been created.
Go back to the terminal and type the following command: pkgutil --flatten FolderName New.pkg (FolderName = the name of the folder and New.pkg = the new .PKG file that will be created)
Press enter and wait for the file to be created
Launch the new .PKG file
Congratulations you can launch the installer.
To continue creating the USB Stick follow the following tutorial : Créer une clé USB bootable
You're done BRAVO !!
5 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
4 comentários
Bonjours après l'étape 5 le terminal me renvois un "Could not open package for expansion: /Desktop/InstallMacOSX.pkg"
pourriez-vous m'aider s'il vous plait
Bonjour,
Avez-vous bien le fichier ".pkg” sur le Bureau (Desktop en anglais) ?
Si oui, êtes-vous bien sûr le bureau dans le terminal ? ("cd Desktop” normalement il affiche "desktop” à gauche de ou vous écrivez.)
Pour être sûr, vous pouvez taper la commande "ls -al", ça affiche une liste et vous pouvez voir s'il y a bien le fichier dans cette liste. S'il n'y est pas, vous n'êtes pas au bon endroit.
Sorry! I've tried with Sierra an always get a Javascript Error... Good try though
Thanks a lot for this guide
