Ir para o conteúdo principal
Creality Ender 3 V2 Extruder Nozzle Replacement
O que você precisa
  1. Creality Ender 3 V2 Extruder Nozzle Replacement, Extruder Nozzle: passo 1, imagem 1 %32
    • Move the extruder carriage to the center of the machine.
  2. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 2, imagem 1 %32
    • Use a 2 mm Allen wrench to remove the two screws located on the back of the extruder shroud.
  3. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 3, imagem 1 %32
    • Carefully remove the shroud by pulling it away from the hot end of the 3D printer.
  4. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 4, imagem 1 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 4, imagem 2 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 4, imagem 3 %32
    • Remove the silicon sleeve around the heat block.
    • Before removing the nozzle, you must bring the printer up to operating temperature in order to remove the leftover filament from the extruder.
  5. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 5, imagem 1 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 5, imagem 2 %32
    • Once the excess filament has been removed, loosen the nozzle by a quarter turn using the wrench provided, then either power off or cool down the printer.
    • Do not attempt to fully remove the nozzle while the printer is at operating temperature. Allow the nozzle to fully cool before removal.
  6. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 6, imagem 1 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 6, imagem 2 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 6, imagem 3 %32
    • Before removing the nozzle check the temperature by bringing the back of your hand near the nozzle; do not touch it. If you feel any heat on the back of your hand, then wait another 10-15 minutes before removing the nozzle.
    • If the nozzle is fully cooled, remove the nozzle.
  7. Creality Ender 3 V2 Extruder Nozzle Replacement: passo 7, imagem 1 %32 Creality Ender 3 V2 Extruder Nozzle Replacement: passo 7, imagem 2 %32
    • Screw on the new nozzle into the heat block with your wrench.
    • To fully tighten the nozzle, bring the printer back to operating temperature and do a final tightening of the nozzle.
    • Printer must be at operating temperature when fully tightening in order to prevent leaks in the future.
Conclusão
Print away!
7 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 13
Últimos 7 dias: 58
Últimos 30 dias: 317
Ao todo: 22,602
