Ir para o conteúdo principal
Creality Ender 3 Pro Extruder Replacement
O que você precisa
  1. Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: passo 1, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: passo 1, imagem 2 %32 Creality Ender 3 Pro Extruder Replacement, Setting the nozzle temperature: passo 1, imagem 3 %32
    • Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
    • Navigate to Temperature > Nozzle.
    • Adjust the nozzle temperature by turning the knob and confirm by pressing it.
    • Use whatever temperature you would be printing with, minus about 10°C. For both PLA and PETG 210°C usually works fine.
  2. Creality Ender 3 Pro Extruder Replacement, Wait for the hotend to heat up: passo 2, imagem 1 %32
    • Wait until the current temperature (bottom) matches the target temperature (top).
  3. Creality Ender 3 Pro Extruder Replacement, Pull the filament: passo 3, imagem 1 %32
    • Press down on the extruder lever arm and pull out the loaded filament.
    • Fully pressing down the lever arm might lead to the filament snagging when you try to pull it out. Just pressing it a bit will usually suffice.
  4. Creality Ender 3 Pro Extruder Replacement, Set cooldown: passo 4, imagem 1 %32
    • Navigate to Temperature and press Cooldown.
    • If you do not have the Cooldown-option available, you can just repeat step one and set the temperature to 0°C instead.
  5. Creality Ender 3 Pro Extruder Replacement, Extruder: passo 5, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement, Extruder: passo 5, imagem 2 %32 Creality Ender 3 Pro Extruder Replacement, Extruder: passo 5, imagem 3 %32
    • Use a 8 mm wrench or some pliers to unscrew the PTFE tube from the extruder mechanism.
  6. Creality Ender 3 Pro Extruder Replacement: passo 6, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement: passo 6, imagem 2 %32
    • Unscrew the single M3x18 socket head screw with a 2.5 mm hex key.
    • Remove the extruder arm and spring.
  7. Creality Ender 3 Pro Extruder Replacement: passo 7, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement: passo 7, imagem 2 %32
    • Use a 2 mm hex key to remove the three remaining M3x10 socket head screws while making sure to not let the motor drop.
    • Remove the plastic bracket and the motor.
  8. Creality Ender 3 Pro Extruder Replacement: passo 8, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement: passo 8, imagem 2 %32 Creality Ender 3 Pro Extruder Replacement: passo 8, imagem 3 %32
    • Install the replacement extruder and screw it to the motor, following all the previous steps backwards.
  9. Creality Ender 3 Pro Extruder Replacement: passo 9, imagem 1 %32 Creality Ender 3 Pro Extruder Replacement: passo 9, imagem 2 %32
    • Reattach the PTFE tube to the extruder and insert some filaments.
Conclusão
Don't forget to recalibrate your E steps!
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 102
Ao todo: 5,662
