Ir para o conteúdo principal
Creality Ender 3 Bracket Plate of Y-Axis Motor Replacement
O que você precisa
  1. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement, Bracket Plate of Y-Axis Motor: passo 1, imagem 1 %32
    • Place the bed plate in the middle of your Ender 3. Do this manually by gently pushing it to the middle.
  2. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 2, imagem 1 %32 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 2, imagem 2 %32
    • Or alternatively, place the bed in the center by turning your Ender 3 on.
  3. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, imagem 1 %32 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, imagem 2 %32 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, imagem 3 %32
    • Turn on the printer, and click the button to the screen shown in the photo.
    • Rotate the button clockwise to "Prepare".
    • Rotate the button clockwise to AutoHome. This should set your bedplate to 0 on both X & Y axes.
  4. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 4, imagem 1 %32
    • Unplug the wire that is connected to the Y motor.
  5. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 5, imagem 1 %32
    • Remove the two M4*20 screws from the back end of the Y-axis bar using an 8 mm Allen Wrench. The side of the display should be facing you.
  6. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 6, imagem 1 %32
    • Remove the four M3*6 screws that are attaching the motor to the Y-axis motor using an 8 mm Allen Wrench.
  7. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 7, imagem 1 %32
    • Buy a new bracket with the same brand (depending on the severity of the bend of the bracket) or straighten the metal on your own.
  8. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 8, imagem 1 %32 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 8, imagem 2 %32
    • If you choose to fix it on your own, slip the bracket in between a workshop bench clamp. Apply enough pressure between two thick blocks of metal to straighten it.
    • Use vise-grips to aid in stabilizing the metal as you force the metal to straighten.
  9. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 9, imagem 1 %32 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 9, imagem 2 %32
    • Repeat, Steps 6-11 in reverse to put the bracet back on the Y motor and back on the Ender 3.
    • Turn on Ender 3 to see if you did it correctly. Try to also print something too!
Conclusão
Isabella Bianca Reano
Membro desde: 04/18/21
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 28
Duração total: 1,869
