Introdução
Nozzles on a 3D printer are considered consumable items, meaning they are commonly replaced during a 3D printer's lifespan. The more you print the quicker the nozzle will wear out.
Reasons to replace a nozzle include:
- Desired nozzle diameter
- Clogged nozzle
- Nozzle deterioration
- First layer failure
- Print speed
This guide will demonstrate how to replace a 3D printer nozzle for the Creality CR 10s Pro V2.
O que você precisa
Using a 2 mm hex key, remove the two screws that secure the fan cover.
Position the fan cover in a way that doesn't damage the external wires.
Remove the silicone sock from the extruder nozzle.
To ensure the nozzle replacement has been followed correctly, calibrate your 3D printer.
