Ir para o conteúdo principal
Crayola Crayon Maker Light Bulb Removal and Replacement
O que você precisa
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, imagem 1 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, imagem 2 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, imagem 3 %32
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, imagem 1 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, imagem 2 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, imagem 3 %32
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, imagem 1 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, imagem 2 %32 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, imagem 3 %32
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Heidi Clarke
Membro desde: 09/21/14
222 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 6,878
