Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If the volume/power control button on your Craig Electronics CMP773 tablet has quit working, this guide will demonstrate how to replace it with the correct tools. During this procedure, be especially careful not to let it fall out when snapping on and off the back cover.
O que você precisa
Remove the two 3.2 mm PH000 screws near the charging port.
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
