Ir para o conteúdo principal
Craig Electronics CMP773 Screen Replacement
O que você precisa
  1. Craig Electronics CMP773 Screen Replacement, Screen: passo 1, imagem 1 %32 Craig Electronics CMP773 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: passo 2, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 2, imagem 2 %32 Craig Electronics CMP773 Screen Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: passo 3, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 3, imagem 2 %32
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: passo 4, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 4, imagem 2 %32
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: passo 5, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 5, imagem 2 %32 Craig Electronics CMP773 Screen Replacement: passo 5, imagem 3 %32
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: passo 6, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 6, imagem 2 %32 Craig Electronics CMP773 Screen Replacement: passo 6, imagem 3 %32
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: passo 7, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 7, imagem 2 %32
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: passo 8, imagem 1 %32
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: passo 9, imagem 1 %32
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: passo 10, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 10, imagem 2 %32
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: passo 11, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 11, imagem 2 %32 Craig Electronics CMP773 Screen Replacement: passo 11, imagem 3 %32
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: passo 12, imagem 1 %32 Craig Electronics CMP773 Screen Replacement: passo 12, imagem 2 %32 Craig Electronics CMP773 Screen Replacement: passo 12, imagem 3 %32
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Conclusão
Justin mersch
Membro desde: 11/07/19
205 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G4, Harley Fall 2019 Membro de IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
Membros da 4
Autoria de 3 guias
Um comentário
What kind of battery does this device specifically use
Kris Miller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 212
