Ir para o conteúdo principal
Craig Electronics CMP773 Front and Rear Camera Replacement
O que você precisa
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: passo 1, imagem 1 %32 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: passo 1, imagem 2 %32
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 2, imagem 1 %32 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 3, imagem 1 %32 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 3, imagem 2 %32
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 4, imagem 1 %32 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 4, imagem 2 %32
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 5, imagem 1 %32
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 6, imagem 1 %32 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 6, imagem 2 %32
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
Conclusão
Luke VanLangevelde
Membro desde: 11/07/19
133 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G4, Harley Fall 2019 Membro de IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 86
