Introdução
In order to replace the LCD screen you must remove all the other parts, starting from the back panel.
O que você precisa
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
After taking out the back cover, locate the black flap.
Open the black flap with the plastic opening tools.
Locate the white plug next to the battery.
Use your fingers to pull off white plug that connected to the battery.
Uma outra pessoa concluiu este guia.
