Introdução
This guide will walk you through the process of replacing the broken front or rear facing camera of a Craig CMP801.
O que você precisa
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
Uma outra pessoa concluiu este guia.
