Ir para o conteúdo principal
Craig CMP801 Battery Replacement
O que você precisa
  1. Craig CMP801 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Craig CMP801 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: passo 2, imagem 1 %32 Craig CMP801 Battery Replacement: passo 2, imagem 2 %32
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: passo 3, imagem 1 %32 Craig CMP801 Battery Replacement: passo 3, imagem 2 %32
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: passo 4, imagem 1 %32 Craig CMP801 Battery Replacement, Battery: passo 4, imagem 2 %32 Craig CMP801 Battery Replacement, Battery: passo 4, imagem 3 %32
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: passo 5, imagem 1 %32 Craig CMP801 Battery Replacement: passo 5, imagem 2 %32 Craig CMP801 Battery Replacement: passo 5, imagem 3 %32
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Where do I find a battery cmp749 ???
kourriclay929 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 991
