Ir para o conteúdo principal
Craftsman Model 315.10721 Table Guard Replacement
O que você precisa
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: passo 1, imagem 1 %32
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: passo 2, imagem 1 %32
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: passo 3, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: passo 4, imagem 1 %32
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Conclusão
Uma outra pessoa concluiu este guia.
Riley Hilliker
Membro desde: 10/14/14
557 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2014 Membro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membros
Autoria de 5 guias
2Comentários do guia
Where can I get a replacement table guard???
Roger Coyle - Responder
Where can I get a replacement table guard for this jig saw????????
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 777
