Ir para o conteúdo principal
Craftsman Model 315.10721 Cord Replacement
O que você precisa
  1. Craftsman Model 315.10721 Cord Replacement, Cord: passo 1, imagem 1 %32
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
    • Each screw has a corresponding nut on the opposite side of the power saw
  2. Craftsman Model 315.10721 Cord Replacement: passo 2, imagem 1 %32
    • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  3. Craftsman Model 315.10721 Cord Replacement: passo 3, imagem 1 %32 Craftsman Model 315.10721 Cord Replacement: passo 3, imagem 2 %32
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
    • Release both the black and white wires and gently pull them from the leads.
    • To install the new cord, insert the wires of the new cord in the same way that they were removed.
Conclusão
Riley Hilliker
Membro desde: 10/14/14
557 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2014 Membro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 512
