Introdução
WARNING: Once the power cord has been identified as the item that needs replacement, make sure that the device is disconnected from any power supply.
O que você precisa
Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
Once the five screws are removed, lift the handle cover from the saw.
Quase terminado!
Conclusão
