Ir para o conteúdo principal
Craftsman Model 315.10721 Brush Replacement
O que você precisa
  1. Craftsman Model 315.10721 Brush Replacement, Brush: passo 1, imagem 1 %32 Craftsman Model 315.10721 Brush Replacement, Brush: passo 1, imagem 2 %32
    • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  2. Craftsman Model 315.10721 Brush Replacement: passo 2, imagem 1 %32
    • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
  3. Craftsman Model 315.10721 Brush Replacement: passo 3, imagem 1 %32
    • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
Conclusão
Riley Hilliker
Membro desde: 10/14/14
557 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2014 Membro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 1,445
