Ir para o conteúdo principal
Craftsman Model 315.10721 Blade Replacement
O que você precisa
  1. Craftsman Model 315.10721 Blade Replacement, Blade: passo 1, imagem 1 %32
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: passo 2, imagem 1 %32
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Linha de Chegada
Riley Hilliker
Membro desde: 10/14/14
557 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 4-47, Amido Fall 2014 Membro de Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
Membros da 4
Autoria de 5 guias
2 comentários
Where can I get replacement blades for this saw.
Edward - Responder
Where can I get replacement blades for this saw?
Edward - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 59
Duração total: 3,367
