Ir para o conteúdo principal
Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
O que você precisa
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: passo 1, imagem 1 %32 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: passo 1, imagem 2 %32
    • Remove the fuel line from the fuel tank with pliers.
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 2, imagem 1 %32 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 2, imagem 2 %32
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 3, imagem 1 %32 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 3, imagem 2 %32
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 4, imagem 1 %32
    • Lift the fuel tank off of the lower supporting brackets.
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 5, imagem 1 %32
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 6, imagem 1 %32
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 7, imagem 1 %32
    • Reconnect the fuel line and hose clamp.
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 8, imagem 1 %32
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
Conclusão
Megan Smith
Membro desde: 10/07/19
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 2,013
