Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide is not for any specific repair, rather it is for cracking the device open in order to diagnose and treat your its inefficiencies.
O que você precisa
Turn the device upside down so that the three rubber pads are facing up.
Um comentário
My product is On Stage I. It's too old. The screw fixing posts protruding from the plastic casing have broken on their own. As a result, the upper and lower shells cannot be completely sealed. When music is played, sound waves leak out of the gaps. It sounds thin and has no depth. It's like placing four speaker units directly outside the enclosure. Bass cannot resonate inside the enclosure, but travels through the bass hole in the middle. I really like this speaker. There's no way I'm giving it up. Is there any way to solve this? Should I look for a used case or use an existing case to rebuild the screw mounting posts? What should I do if I choose to rebuild?
