Ir para o conteúdo principal
Cracked Grout Replacement
O que você precisa
  1. Cracked Grout Replacement, Cracked Grout: passo 1, imagem 1 %32 Cracked Grout Replacement, Cracked Grout: passo 1, imagem 2 %32
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: passo 2, imagem 1 %32
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: passo 3, imagem 1 %32 Cracked Grout Replacement: passo 3, imagem 2 %32
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: passo 4, imagem 1 %32 Cracked Grout Replacement: passo 4, imagem 2 %32
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: passo 5, imagem 1 %32
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: passo 6, imagem 1 %32 Cracked Grout Replacement: passo 6, imagem 2 %32 Cracked Grout Replacement: passo 6, imagem 3 %32
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: passo 7, imagem 1 %32 Cracked Grout Replacement: passo 7, imagem 2 %32 Cracked Grout Replacement: passo 7, imagem 3 %32
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: passo 8, imagem 1 %32 Cracked Grout Replacement: passo 8, imagem 2 %32
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: passo 9, imagem 1 %32
    • Your new grout is dry and ready for use.
Conclusão
To repair any other cracks in grout, repeat these steps.
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 101
Duração total: 2,360
