Ir para o conteúdo principal
Cr-48 Chromebook SSD Replacement
O que você precisa
  1. Cr-48 Chromebook SSD Replacement, Battery: passo 1, imagem 1 %32 Cr-48 Chromebook SSD Replacement, Battery: passo 1, imagem 2 %32 Cr-48 Chromebook SSD Replacement, Battery: passo 1, imagem 3 %32
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: passo 2, imagem 1 %32 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, imagem 1 %32 Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, imagem 2 %32 Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, imagem 3 %32
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: passo 4, imagem 1 %32 Cr-48 Chromebook SSD Replacement: passo 4, imagem 2 %32 Cr-48 Chromebook SSD Replacement: passo 4, imagem 3 %32
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, imagem 1 %32 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, imagem 2 %32 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, imagem 3 %32
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: passo 6, imagem 1 %32 Cr-48 Chromebook SSD Replacement, Remove SSD: passo 6, imagem 2 %32
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
Conclusão
5 outras pessoas executaram este guia.
Athar
Membro desde: 09/09/14
365 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-2, Bruce Fall 2014 Membro de CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 14
Últimos 30 dias: 66
Duração total: 3,218
