Ir para o conteúdo principal
Cowin E7 Ear Cushion Replacement
O que você precisa
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: passo 1, imagem 1 %32
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: passo 2, imagem 1 %32
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: passo 3, imagem 1 %32
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
Linha de Chegada
4 outras pessoas executaram este guia.
Jacob Burrer
Membro desde: 03/26/22
439 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-2, Mellen Spring 2022 Membro de UMass Dartmouth, Team 2-2, Mellen Spring 2022
UMASSD-MELLEN-S22S2G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 46
Últimos 30 dias: 190
Duração total: 4,940
