Ir para o conteúdo principal
Cover Panel Disassembly
O que você precisa
  1. Cover Panel Disassembly, Cover Panel: passo 1, imagem 1 %32
    • Find the mating groove running along the side of device. Use an ifixit opening tool to pry the two mating surfaces apart with a twisting motion.
    • Once the surfaces have been separated, using your fingers, pull the two surfaces apart evenly around the edge of the device.
    • During reassembly, be sure to press the two pieces together all the way around the perimeter to ensure good connection.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these steps in reverse order.
Equipe
IUPUI, Team 2-5, Baechle Fall 2016 Membro de IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 57
Ao todo: 509
