Introdução
The Cosco step stool is a common house hold item that has been around for decades. Older Cosco step stools tend to get worn and need replacements to still be functional. This guide will show you how to disassemble the seats from a Cosco Step Stool Stylaire (model 44-B) and replace the cushion and upholstery material.
O que você precisa
Cut two pieces of foam for each seat cushion.
Bottom seat: 14" x 12"
Back rest: 14" x 6"
To reassemble your device, follow steps 3-5 in reverse order, using a hammer to push down the tabs.
7 outras pessoas executaram este guia.
2 comentários
Best directions ever...Very detailed which saved me a lot of work that wasn't needed..
