Ir para o conteúdo principal
Corsair Void Pro RGB Volume Switch Replacement
O que você precisa
  1. Corsair Void Pro RGB Volume Switch Replacement, Earcup: passo 1, imagem 1 %32
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Volume Switch Replacement: passo 2, imagem 1 %32 Corsair Void Pro RGB Volume Switch Replacement: passo 2, imagem 2 %32
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Volume Switch Replacement: passo 3, imagem 1 %32 Corsair Void Pro RGB Volume Switch Replacement: passo 3, imagem 2 %32
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Volume Switch Replacement, Volume Switch: passo 4, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Volume Switch Replacement: passo 5, imagem 1 %32
    • Pull the volume switch out and remove it from the device.
Conclusão
Gianna Nobili
Membro desde: 04/15/19
827 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S9-G13, Maness Spring 2019 Membro de Cal Poly, Team S9-G13, Maness Spring 2019
CPSU-MANESS-S19S9G13
Membros da 4
Autoria de 14 guias
Um comentário
Heads up, some headsets have hot glue holding the wiring down below the speakers, and sometimes the hot glue will grab the speaker frame so its impossible to teardown the headset without damaging the wires, speaker or PCB board.
Found this out when my volume wheel was catching on something, so i decided to check it out. It was a glob of glue in the way of the wheel making it difficult to hit the switch to adjust the volume. Took me a little creative thinking to remove it with a plastic pointer/ scraper, and some fine tweezers, as the speaker panel was being held down by a large glob of glue.
USB Lynx - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 42
Duração total: 2,771
