Ir para o conteúdo principal
Corsair M55 RGB Pro Gaming Mouse Motherboard
O que você precisa
  1. Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: passo 1, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: passo 1, imagem 2 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: passo 1, imagem 3 %32
    • Use a spudger to gently peel off and remove the three mouse feet on the bottom of the mouse.
    • If you are not replacing the mouse feet with a new set, put them aside to replace them at the end of the repair.
  2. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 2, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 2, imagem 2 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 2, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws from the bottom of the mouse.
    • There is a cable connecting the bottom and top of the mouse.
  3. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 3, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 3, imagem 2 %32
    • Use a spudger to separate the top and bottom of the mouse.
    • Don't pull them apart as they are connected by a cable connector and could become damaged.
    • Pull the PCB cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  4. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 4, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 4, imagem 2 %32
    • Pull the USB pin cable away from the connector in the same direction as the individual wires are running.
  5. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 5, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 5, imagem 2 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 5, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws that secure the motherboard.
  6. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 6, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 6, imagem 2 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 6, imagem 3 %32
    • Carefully lift the motherboard out of the base of the mouse by the edges.
  7. Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 7, imagem 1 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 7, imagem 2 %32 Corsair M55 RGB Pro Gaming Mouse Motherboard: passo 7, imagem 3 %32
    • If necessary, remove the mouse wheel by sliding it to the right.
    • It should come out of the slot easily as it's not attached.
Conclusão
Rizza Barnwell
Membro desde: 03/05/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 26
Duração total: 64
