Ir para o conteúdo principal
Corsair Katar USB Cable Replacement
O que você precisa
  1. Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: passo 1, imagem 1 %32 Corsair Katar USB Cable Replacement, Corsair Katar Disassembly: passo 1, imagem 2 %32
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar USB Cable Replacement: passo 2, imagem 1 %32
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar USB Cable Replacement: passo 3, imagem 1 %32 Corsair Katar USB Cable Replacement: passo 3, imagem 2 %32
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar USB Cable Replacement: passo 4, imagem 1 %32
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar USB Cable Replacement, USB Cable: passo 5, imagem 1 %32 Corsair Katar USB Cable Replacement, USB Cable: passo 5, imagem 2 %32
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar USB Cable Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar USB Cable Replacement: passo 7, imagem 1 %32 Corsair Katar USB Cable Replacement: passo 7, imagem 2 %32
    • Use the JIS 0 screwdriver to remove the 5mm screw attached to the USB wire housing.
    • Lift the USB wire away from the shell of the mouse.
    • When reassembling the device, run the USB wire through the channel on the bottom of the shell to keep it in place.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 23
Duração total: 1,293
