Introdução
If the scroll wheel sensor on your Corsair Katar mouse is broken, this guide will show you how to replace it.
O que você precisa
Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
2Comentários do guia
bonsoir moi ma molette tourne dans le vide rien ne accroche merci
Do I need new pads when I take out the old ones or will the same one stick?
