Ir para o conteúdo principal
Corsair Katar Scroll Wheel Replacement
O que você precisa
  1. Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: passo 1, imagem 1 %32 Corsair Katar Scroll Wheel Replacement, Corsair Katar Disassembly: passo 1, imagem 2 %32
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Scroll Wheel Replacement: passo 2, imagem 1 %32
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Scroll Wheel Replacement: passo 3, imagem 1 %32 Corsair Katar Scroll Wheel Replacement: passo 3, imagem 2 %32
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Scroll Wheel Replacement: passo 4, imagem 1 %32
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Scroll Wheel Replacement, Scroll Wheel: passo 5, imagem 1 %32 Corsair Katar Scroll Wheel Replacement, Scroll Wheel: passo 5, imagem 2 %32
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Scroll Wheel Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Scroll Wheel Replacement: passo 7, imagem 1 %32
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
Conclusão
Equipe
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 55
Duração total: 1,961
