Ir para o conteúdo principal
Core Assembly Removal
O que você precisa
  1. Core Assembly Removal, Unfasten the screws: passo 1, imagem 1 %32
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the four 3.9 mm-long Torx T3 screws.
    • Depending on the condition of your driver, a Torx T4 bit may fit better.
    • Don't try to detach the back cover yet. It is still connected to the watch assembly.
    Pergunte ao FixBot
    Comentar
  2. Core Assembly Removal, Open the watch: passo 2, imagem 1 %32 Core Assembly Removal, Open the watch: passo 2, imagem 2 %32
    • Be careful not to strain the sensor flex cable during this procedure.
    • Carefully lift the back cover by the watch crown edge and swing it open to an upward position.
    Pergunte ao FixBot
    Comentar
  3. Core Assembly Removal, Disconnect the sensor cable: passo 3, imagem 1 %32 Core Assembly Removal, Disconnect the sensor cable: passo 3, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable.
    Pergunte ao FixBot
    Comentar
  4. Core Assembly Removal, Remove the back cover: passo 4, imagem 1 %32
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  5. Core Assembly Removal, Core Assembly Removal: passo 5, imagem 1 %32
    • Remove the three 3.7 mm-long Phillips #00 screws.
    Pergunte ao FixBot
    Comentar
  6. Core Assembly Removal: passo 6, imagem 1 %32 Core Assembly Removal: passo 6, imagem 2 %32 Core Assembly Removal: passo 6, imagem 3 %32
    • Insert the flat end of a spudger into the notch at the upper end of the white plastic frame.
    • Use your spudger as a lever and pry up the core assembly.
    • Don't try to remove the core assembly all the way yet—it is still connected to the watch body.
    Pergunte ao FixBot
    Comentar
  7. Core Assembly Removal: passo 7, imagem 1 %32 Core Assembly Removal: passo 7, imagem 2 %32
    • Carefully lift the loose edge of the core assembly up and swing it to a 100-degree angle.
    • Be careful not to strain the display and sensor flex cables during this procedure.
    Pergunte ao FixBot
    Comentar
  8. Core Assembly Removal: passo 8, imagem 1 %32 Core Assembly Removal: passo 8, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the core assembly.
    Pergunte ao FixBot
    Comentar
  9. Core Assembly Removal: passo 9, imagem 1 %32 Core Assembly Removal: passo 9, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the display flex cable from the core assembly.
    Pergunte ao FixBot
    Comentar
  10. Core Assembly Removal: passo 10, imagem 1 %32
    • Remove the core assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Check out our Answers community for help.
4 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
259.457 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 25.998 guias
1Comentário do guia
Hello... in the event that you have submerged the smartwatch in salt water and it does not work, is there a solution?
luciano.alonso84@gmail.com - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 1,640
