Ir para o conteúdo principal
Copic Marker Nib Replacement
O que você precisa
  1. Copic Marker Nib Replacement, Copic Marker Nib: passo 1, imagem 1 %32
    • Place a few paper towels on the surface of your workspace to protect it from ink spills.
  2. Copic Marker Nib Replacement: passo 2, imagem 1 %32
    • Remove the cap from the marker to expose the nib.
  3. Copic Marker Nib Replacement: passo 3, imagem 1 %32 Copic Marker Nib Replacement: passo 3, imagem 2 %32 Copic Marker Nib Replacement: passo 3, imagem 3 %32
    • Gently tug out the thicker part of the nib with the tweezer.
  4. Copic Marker Nib Replacement: passo 4, imagem 1 %32 Copic Marker Nib Replacement: passo 4, imagem 2 %32
    • Remove the cap of the ink bottle and tilt the container to begin filling the marker.
    • Avoid forcibly squeezing the ink bottle.
    • Slowly fill the pen until it is approximately 3/4ths of the way full.
  5. Copic Marker Nib Replacement: passo 5, imagem 1 %32 Copic Marker Nib Replacement: passo 5, imagem 2 %32 Copic Marker Nib Replacement: passo 5, imagem 3 %32
    • Insert the flat side of the new nib facing the opening of the marker until it snaps into place.
    • Set the marker down after replacing new nib.
  6. Copic Marker Nib Replacement: passo 6, imagem 1 %32 Copic Marker Nib Replacement: passo 6, imagem 2 %32 Copic Marker Nib Replacement: passo 6, imagem 3 %32
    • Wait 3 minutes for the color to spread through the nib until it is no longer white.
    • Press on the middle of the marker 3 times to insure ink is spread throughout.
    • Repeat steps 3 - 5 if the amount of ink is insufficient.
Linha de Chegada
Iris Lin
Membro desde: 04/28/17
149 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G5, Coad Spring 2017 Membro de UC Davis, Team S1-G5, Coad Spring 2017
UCD-COAD-S17S1G5
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 2,835
