Ir para o conteúdo principal
Coolpix S01 Screen Cover Replacement
O que você precisa
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, imagem 1 %32 Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, imagem 2 %32 Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, imagem 3 %32
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: passo 2, imagem 1 %32 Coolpix S01 Screen Cover Replacement: passo 2, imagem 2 %32 Coolpix S01 Screen Cover Replacement: passo 2, imagem 3 %32
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: passo 3, imagem 1 %32 Coolpix S01 Screen Cover Replacement: passo 3, imagem 2 %32 Coolpix S01 Screen Cover Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: passo 4, imagem 1 %32 Coolpix S01 Screen Cover Replacement: passo 4, imagem 2 %32 Coolpix S01 Screen Cover Replacement: passo 4, imagem 3 %32
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 453
