Ir para o conteúdo principal
Coolpad Defiant Rear Camera Replacement
O que você precisa
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: passo 1, imagem 1 %32 Coolpad Defiant Rear Camera Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: passo 2, imagem 1 %32
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: passo 3, imagem 1 %32
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: passo 4, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: passo 5, imagem 1 %32 Coolpad Defiant Rear Camera Replacement: passo 5, imagem 2 %32
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: passo 6, imagem 1 %32
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: passo 7, imagem 1 %32 Coolpad Defiant Rear Camera Replacement: passo 7, imagem 2 %32 Coolpad Defiant Rear Camera Replacement: passo 7, imagem 3 %32
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: passo 8, imagem 1 %32 Coolpad Defiant Rear Camera Replacement: passo 8, imagem 2 %32 Coolpad Defiant Rear Camera Replacement: passo 8, imagem 3 %32
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: passo 9, imagem 1 %32
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 267
