Ir para o conteúdo principal
Coolpad Defiant Battery Replacement
O que você precisa
  1. Coolpad Defiant Battery Replacement, Back Cover: passo 1, imagem 1 %32 Coolpad Defiant Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: passo 2, imagem 1 %32
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: passo 3, imagem 1 %32
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Ao todo: 1,794
