Introdução
Overheating laptops can be a serious problem. Luckily devices like the Cooler Master Laptop
Fan can help keep your laptop cooler than the fans in your laptop can. This helps extend the life
of your laptop and allows better performance for your laptop as well. However even laptop fans
can fail and need to be replaced.
O que você precisa
Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
