Ir para o conteúdo principal
Cooler Master Laptop Fan Replacement
O que você precisa
  1. Cooler Master Laptop Fan Replacement, Fan: passo 1, imagem 1 %32
    • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
    • Never try to open the cooler while plugged in.
  2. Cooler Master Laptop Fan Replacement: passo 2, imagem 1 %32
    • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
  3. Cooler Master Laptop Fan Replacement: passo 3, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 3, imagem 2 %32 Cooler Master Laptop Fan Replacement: passo 3, imagem 3 %32
    • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
  4. Cooler Master Laptop Fan Replacement: passo 4, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 4, imagem 2 %32
    • Remove the cover and expose the inside of the Cooler.
  5. Cooler Master Laptop Fan Replacement: passo 5, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 5, imagem 2 %32
    • Unplug the power cable to the fan.
    • Make sure not to apply too much force and disconnect the wires to the device.
  6. Cooler Master Laptop Fan Replacement: passo 6, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 6, imagem 2 %32
    • On the bottom of the base locate the screw holes under the sticker on the base.
    • Unscrew the three fan screws.
  7. Cooler Master Laptop Fan Replacement: passo 7, imagem 1 %32
    • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
  8. Cooler Master Laptop Fan Replacement: passo 8, imagem 1 %32
    • Apply a small amount of thermal compound to the base where the fan sets.
    • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
  9. Cooler Master Laptop Fan Replacement: passo 9, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 9, imagem 2 %32
    • Connect power cable for the fan and place the cables back in their slots.
  10. Cooler Master Laptop Fan Replacement: passo 10, imagem 1 %32 Cooler Master Laptop Fan Replacement: passo 10, imagem 2 %32
    • Screw fan back onto base.
  11. Cooler Master Laptop Fan Replacement: passo 11, imagem 1 %32
    • Place cover back on base.
  12. Cooler Master Laptop Fan Replacement: passo 12, imagem 1 %32
    • Fold all metal flaps back to hold cover on base.
  13. Cooler Master Laptop Fan Replacement: passo 13, imagem 1 %32
    • Flip it over and it's finished.
Conclusão
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
2 comentários
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - Responder
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 80
Duração total: 5,723
