Introdução
This guide will give you step-by-step instructions on how to replace the back door on your Contour Roam2. Follow this guide if it is damaged or the stays button is no longer working.
O que você precisa
Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
Using a paper clip or a SIM eject tool size 0.8, push the metal bar out from the spring located on bottom of back door.
Uma outra pessoa concluiu este guia.
